Decimal to binary two's complement
Hello!
I want to convert a decimal number (from -32768 to 32767) into a 16 bits Binary two's complement.
Any suggestion?
Thank you in advance!
(6,937 Views)
What is the datatype of the "decimal number"? A I16 numeric integer? A decimal string?
What output do you want? (binary string? I16 numeric?) What is the byte order?
It always helps to attach a small VI containing your input in a diagram constant to avoid ambiguities. Thanks!
(6,928 Views)
I have a dac714 which is designed to accept binary two’s complement input codes with the MSB first. The output voltage range I want to obtain is ±5 V. What I am doing is to convert voltage values (DBL control, so that the user can select the desired voltage) into decimal values from -32768 to 32767 (DBL). What i want to get is a 1D array of boolean that goes in a digital output of my  usb 6211 and then into the dac.
I hope I was clear.
(I don't attach my VI because this is a small part of a very crowded one, I try to simplify it and attach later a simpler version)
Thank you
(6,904 Views)
Here is a simpler version of what I did so far. The conversion here is from digital to binary, what I wish is from digital to binary two's complement.
(6,894 Views)
Accepted by topic author Giulia30
Your code makes absolutely no sense.
Maybe this can give you some ideas.
(6,881 Views)
Thank you.
(6,870 Views)
Stupid question: Why not just use an Analog Output on the USB-6211?  Or is the DAC714 the UUT?
(6,792 Views)
