Decoding non printing characters
I am working with a VI that invokes a telnet session. The responses come back in multiple line formats. What's a quick way to translate the non-printing characters so I can see what to use for delimiters? Using platform dependent EOL does not work which I expected since this data is coming straight from the UUT.
jvh
(3,378 Views)
Accepted by jvh75021
jvh
I will noramlly put the data in a string indicator and set it for either slash code or hex display. If that gets to hard to read, cast the string as an array of bytes and display that.
Ben
(3,371 Views)
Took me a minute or two to find it under properties, but back slash character representation is the trick!
Thanks.
@Ben wrote:
jvh
Ben
(3,351 Views)
Just right-click on the control/indicator and select the display mode. Smiley Wink
(3,348 Views)
