Delete an item from menu ring
Hi
How to delete an item from ring control.
I am able to add a n item to ring control but not able to delete an item.pls give me suggestions how to do that.
Message 1 of 18
(3,901 Views)
Hi Veeru,
you connect an array to the property node and all elements contained in this array will be displayed in the ring, so if you connect an array with other elements you can chage the visible elements. If you read the old elements, delete some of them and write the new array to the property node, then you delete them.
Hope it helps.
Mike
Message 2 of 18
(3,897 Views)
Is this what u need?
Hope this helps!
Mathan
Message 3 of 18
(3,896 Views)
Thanks Mike and Mathan
Mathan,in that example i am not able to 1 element(whatever the last element in the control remains there).
Message 4 of 18
(3,878 Views)
I'm not sure what 'able to 1 element' means but if you can't delete the last element, you've done something wrong. As usual, you need to post your code if you expect help in fixing it.
Message 5 of 18
(3,870 Views)
Thanks Dennis
Sorry that program"Deleting an element from control is working "on its own,but i have problem in the attached vi"Add"
Message 6 of 18
(3,851 Views)
Your code makes no sense. Why do you have a loop for the Delete operation? Your "Add" VI is doing both an add and a delete, but the add only if you press the button.
Message 7 of 18
(3,839 Views)
Thanks Smercurio
Sorry for late reply
The vi i attached "Add" didnt deletes all the value and not adding any values,could u tell me what is the error
Message 8 of 18
(3,818 Views)
Hi Veeru,
what do you mean with "didn´t delete all the values"? At the moment you can delete only one element per iteration. How shall your vi work?
Mike
Message 9 of 18
(3,816 Views)
Thansk mike
Yes,it deletes only 1 element per iteration.when we keep deleting the elements step by step 1 or 2 elements is not deleted. when i use the program for deleting the elements on its own i am able to.i am sure in that Add vi i have made mistake but i dont know what is that.
Thansk
Message 10 of 18
(3,814 Views)
