Delete ## and empty line from txt files
I have problem with my program.
I need to delete empy lines from my txt file.
This file is look like:
## Normalised capacitance data file
## Capacitance model: Parallel (K = 3.0)
## Created by: ECT32v2 for Win32 Beta2.25 (Jul 10 2003 01:54:24)
## Source: rec_flow_f45_v800_n2.bcp
##    Description: Contents of capture mode buffer
##    Date: 12:04:43 GMT Standard Time, 29Mar04
## Electrodes = 8, Measurements = 28
## Data for Plane 1
## frame 1 (0 msec)
0.006 -0.001 -0.004 -0.002 -0.028 -0.002 0.031
-0.008 -0.005 -0.007 -0.024 0.005 0.004
-0.014 -0.002 -0.011 -0.004 0.002
-0.008 -0.003 0.004 -0.003
-0.011 0.002 0.001
0.004 0.005
0.008
## frame 2 (10 msec)
0.005 -0.002 -0.008 -0.002 0.006 0.011 0.023
-0.008 -0.004 -0.004 -0.010 0.001 0.003
-0.007 -0.001 -0.012 0.007 0.008
-0.015 -0.004 0.002 0.001
-0.007 -0.002 0.001
0.008 -0.002
0.005
I want to delete all empty lines, lines which contain "##"
I try like attachment but it doesn't work.
How can I do this?
Regads,
Sorry for my english
Message 1 of 10
(6,671 Views)
You need two tests. One for the empty lines and another for the lines starting with ##.
I converted the string to an array of strings. Then test each element of the array. Using conditional indexing, I build an output array of strings containing only the data elements. Then I convert that back to a single string.
Lynn
Message 2 of 10
(6,639 Views)
## Data for Plane 1
## frame 1 (0 msec)
-0.011 0.002 0.001
0.004 0.005
0.008
-0.007 -0.002 0.001
0.008 -0.002
0.005
How can I do this?
Regads,
Hello piotrek0492,
The lines that contains ## are not empty, so what would you like to do?
Michel
Message 3 of 10
(6,634 Views)
This will work but not necessarily for just lines starting with ## but also if ## appear in between (very unlikely given the file format). If that is a possibility, you have to use a regex.
^ will ensire it is checked at the beginning.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 4 of 10
(6,618 Views)
First of all, please do us the courtesy of submitting executable code (attaching a VI is the easiest way to do this) so that we don't have to recreate your program ourselves to test it.
Have you taken the freely-available LabVIEW tutorials and spend a few hours learning the basics of LabVIEW?  Have you programmed up the example code in the Tutorials for yourself and tried making small changes to get it to do other things?
Sometimes it is helpful to think about the problem before jumping into coding.  Here's how I see your task:
  • The input is a text file, with text being given in lines
  • The output will be another text file consisting of some of the lines of the input
  • Lines that start with "##" will not be part of the output
  • Lines that are blank will not be part of the output
  • All other lines will be part of the output
Do you see any "logical structure" to this description?  Are there obvious loops, obvious "branch" decision points?  What LabVIEW constructs handle loops?  How do you read lines of text?  How do you selectively output lines of text?
Message 5 of 10
(6,594 Views)
Good advise has already been provided.
But just for fun here is a couple of loops that will perform parsing functions that may work depending on your desired outcome.
Yes there are other ways but you can trace through the code maybe pick up something along the way.
Good luck
Message 6 of 10
(6,580 Views)
For the fun of it I tried to get a solution without loops.
Ben64
Message 7 of 10
(6,532 Views)
Accepted by piotrek0492
Ben thanks for the example. Somehow I had missed the setting that allowed the expresion search. Your example sent me back to the help files to figure it out. I have modified my first code to show the method I hope  I have the explaination correct. Not trying to do someones homework for them but for those who need a quick start perhaps this will help someone else along the way.
Message 8 of 10
(6,477 Views)
A little difference with my method is that it also remove the space and the line feed after the final 0.005 value.
Ben64
Message 9 of 10
(6,467 Views)
thanks for all the answers.
It helped me in solving tasks and accede to the further stages of the work.
Regards
Message 10 of 10
(6,460 Views)
