Delete clicked item from Listbox (Single Column)
There seems to many posts on deleting rows from multicolumn listbox programmatically but not from single column listboxes.
Woth the help of Blokk and
Make an array of the items clicked in a list
(6,297 Views)
Accepted by amithkuttan
Have an array of strings for the 'ItemNames' that go into the listbox and store it on a shift register. When you delete an item (e.g. from an event case), remove that item from the list (using delete from array) and write it back to the ItemNames property of the listbox. A single column listbox works in exactly the same way as a multicolumn listbox.
(excuse the broken links to the properties - this happens when creating a snippet)
(blog)
(6,284 Views)
Thank you so much Sam_Sharp. You've given me more insight into how to use Listbox.
May I ask why do you have the error out connected to the while loop?
(6,273 Views)
It's not really necessary - but it's just there to make sure that the property node executes (and writes the items to the listbox) before the while loop starts (dataflow!).
(blog)
(6,265 Views)
Use the Code Capture Tool rather than NI's built in VI snipped option and you won't have that problem.
(6,257 Views)
Yes, although I have noticed that NI did apparently fix these issues with LV 2015 (but the CCT still has some advantages, like including the FP in the image or backsaving the snippet).
___________________
Try to take over the world!
(6,241 Views)
