Denver Instrument TP-12 Balance with VISA in LV 2013
Hello!
I am having some issues with a Denver Instrument TP-12 analytical balance.
I have set up the balance and made sure that all the VISA settings match in LabVIEW.
I do manage to read accurate weight from the balance, and the read buffer works correctly, but every 30 seconds or so the read buffer gets filled with gibberish (random non-numeric characters) and so the numeric data (after converting from String to Numeric) is read as 0.
I contacted Denver Instrument (now Sartorius) and was told that the problem probably lies in LV.
Attached is the VI that I am using as well as screenshots of the read buffer when it reads the gibberish.
Any advice as to why I am having these weird reading and what I can do to either prevent them or a method to have the numeric data ignore the spikes in the reading would be GREAT!
Thanks-in-advance,
 4Strings
(3,356 Views)
Accepted by 4Strings
In order to know if LabVIEW is the culprit of this behavior, it might be very helpful to use this architecture :
and tell us if you see the same behavior.
(3,334 Views)
It worked!
Thank you SO much!
-4Strings
(3,316 Views)
Thanks for your feedback !
Producer/Consumer is one of the most powerful architecture for data processing/logging :
     - One loop (one process) to acquire datas
     - One loop for processing/logging
By using this architecture, you are sure to remove 99,9 % of acquisitions issues.
Cheers,
(3,279 Views)
Thanks!
How would I log more data streams from other sensors (from temperature probes, condutivity probes, etc.)?
Do I just add separate ques for each of them in the producer loop, or can I add them to the first que?
Thanks again,
4Strings
(3,269 Views)
Hi 4Strings,
Mathieu_T had a great advice when he recommended the producer/consumer loop. If you want to pass multiple datatypes with the queue structure, I would recommend grouping the data into a cluster or an array, since a queue can only handle one data type (e.g. a cluster containing a string and a double).
There's a bit more information on the producer/consumer loop here: https://www.ni.com/en/support/documentation/supplemental/21/producer-consumer-architecture-in-labvie...
Rick C.
(3,242 Views)
