Desparate for working VI for Keithley 2400 to do VI sweep
I am in desparate need of a program that will perform a VI  sweep of a pv cell on the Keitley 2400. Due to time contriants and lack of access to the machine i am unable to develop the software in time.
I am willing to imburse the helper for their time or for a full program up to £200-£250(i am a student).
The program will need to do an iv sweep with enough resolution to gain a graph,
open circuit voltage, short circuit current, fill factor, maximum power point
current and voltage and the Efficiency.
I can run the program in labVIEW 2009, 2011, or 2013
Thank you in advance
If you can help then please email me at ninnortheast@gmail.com
(3,931 Views)
Do I get your degree, too?
Bill
CLD
(Mid-Level minion.)
(3,901 Views)
Accepted by ninnorth
I don't want a degree in Management...
(3,895 Views)
It's unlikely you'll find anyone on these forums willing to do the entire project for you, ESPECIALLY since it's for a class.  There are partial code segments throughout the forums, such as http://forums.ni.com/t5/LabVIEW/Error-code-110-in-keithley-2400/m-p/2680579#M797618 , in regards to controlling the Keithley 2400 for an IV sweep which will help you get started with the commands you'd need to send.  IN FACT, Keithley's manual provides an example of a voltage sweep (which is the example that I followed to develop our IV test stand code).  With such example code you should be able to get a full VI running in a matter of days.
All you'd need is your computer and a student evaluation version of LabVIEW.
(3,889 Views)
