Detect differences between cup anemometer bearings in a wind tunel
Instead of microphones, perhaps try an accelerometer mounted to anemometer near the bearings?
-AK2DM
Message 11 of 14
(954 Views)
I already did that, using an adxl3xx accelerometer, which was unable to detect any vibration from the anemometer. My guess is that it's not sensitive enough to detect such a low scale vibrations. Do you have any tip on how to properly select an accelerometer for an application like this?
Message 12 of 14
(948 Views)
Bummer, was the accelerometer oriented in the correct axis and signal conditioning used?
I don't have any tips regarding selection, what is the expected frequency range of the vibration?
How about a contact microphone or stethescope type pickup? They may have too limited bandwidth though.
http://www.te.com/commerce/DocumentDelivery/DDEController?Action=srchrtrv&DocNm=Contact_Microphone_C...
-AK2DM
Message 13 of 14
(942 Views)
I acquired both x and z axison the shaft of the anemometer, wasn't that the correct approach? What would be the correct axis in this case?
What do you mean by the signal conditioning I should use? All I got was noise varying over pretty much all the frequency ranges, there was no proper way to filter it.
The anemometer cups rotate between 4-16m/s, which translates to a frequency from ~60-250Hz. So I should expect something at that frequency and then some harmonics at higher frequencies, if I envelope the signal. Or is my line of thinking wrong?
Message 14 of 14
(936 Views)
