Determine which LavbVIEW Version a function needs
Hello there,
right now I am using the Evaluation Version of LabVIEW 2024 Q3 and i would like to determine, which Version (Base, Full, Professional) i will need.
I'd like to determine which LavbVIEW Version a function needs.
There is a page in the support section, which states that you can get to know the required version, if you click on "help" on the program: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000015A76SAE&l=de-DE
However this opens the Help webpage, which does not state the required version. How do I determine a function's required Version now?
Greetings
Theo
Message 1 of 11
(2,956 Views)
@Theomen wrote:
Hello there,
Greetings
Theo
Great - one more thing to hate about the online help.  It used to be that the help for each function had this info.
Bill
CLD
(Mid-Level minion.)
Message 2 of 11
(2,925 Views)
I guess the purchasing decision should not be based on a single function, but on what you actually intend to do. Also many simple "pro" or "full" functions could easily be implemented from scratch is "base" from a few primitives.
Are you planning to build standalone executables?
I thought there was a configuration to use the local help instead. I'll try to find it.
Message 3 of 11
(2,912 Views)
Windows Start->National Instruments->NI Help Preferences
Message 4 of 11
(2,905 Views)
I thought the local help was just the remote help in a pdf?
Bill
CLD
(Mid-Level minion.)
Message 5 of 11
(2,899 Views)
It looks like NI missed this when they moved to the new help format.  I'm not seeing it in the offline help either.
Is there a specific function you are curious about?  I can check to see the required edition using an older version (2019).
Message 6 of 11
(2,895 Views)
Nope. Take the web help experience and move it into its own application.
Message 7 of 11
(2,893 Views)
First of all - thank you all for the quick answers.
I'm not planning on building any standalone executables (i think i'd need the application builder for this?)
I have an I/O Box from NI (USB-6002) and i want to read the analog input and generate an analog output signal. Since on the edition selection page no boxes ticked for signal processing and control i am not sure whether this is possible with the Base Edition or if i need the Full Edition for this.
Message 8 of 11
(2,817 Views)
That would be very nice of you.
One function i am curious about is the "generate signal" function under signal processing/wfm generation.
Message 9 of 11
(2,815 Views)
Accepted by topic author crossrulz
For 'Signal Processing VIs' -> 'Signal Generation VIs' -> 'Sine Wave VI' the offline help in LV2022Q3 states: 'Requires: Full Development System'
Message 10 of 11
(2,799 Views)
