09-22-2006 03:38 PM
09-22-2006 04:00 PM
09-22-2006 04:03 PM
09-22-2006
04:07 PM
- last edited on
05-29-2025
03:24 PM
by
Content Cleaner
Hi heepofajeep,
Fisrt we have to see if the board is working correctly. The best thing to do, is to use the Test Panels in MAX. Open Max, go to Device and Interfaces, NI-DAQmx Devices, click on you device, and then look for the "Test Panels" button. Then in the Test panels, go to Digital I/O, select Port 1, then click the button "All ouput", and then in the "Select State" section, change the switches, the values of the lines of the port, do that you can check with your oscilloscope.
Also you can use the next utility to test you board, be sure to have the board disconected from any signal:
https://www.ni.com/en/support/downloads/software-products/download.daq-diagnostic-utility.html
Whar version of NI-DAQmx are you using?
Let me know how it turns out.
Tania Lozoya
09-23-2006
06:15 AM
- last edited on
05-29-2025
03:29 PM
by
Content Cleaner
PFI5 is pin 6 is port 1 line 5 ![]()
PFI's are always port 1 to give room to use port 0 for buffered in/output
Pin 51 is port 0 line 5
manual
Ton
09-23-2006 09:22 AM
09-26-2006 01:39 AM
09-26-2006 09:11 AM
09-26-2006 11:55 AM
09-26-2006 12:08 PM
