Digital to analog converter?
i have a ADC[analog to Digital converter] output connected to the digital input module[cFP-DI-100]. Is it possible to realise a DAC[Digital to Analog Converter in LabVIEW?
(3,584 Views)
Hi ELUE,
You can use the Interpolate 1D VI in LabVIEW to convert digital data to analog data.
According to the LabVIEW help, this VI:
Performs one-dimensional interpolation using a selectable table-lookup method. This VI accepts tabulated dependent and independent variable values Y and X and provides interpolated values yi corresponding to each xi location. This VI finds each value of xi in X and uses the relative location in X to find the interpolated value yi at the same relative location in Y.
This VI is not available in the Base Package of LabVIEW, so if you do not have the Full or Professional versions of LabVIEW please let me know so we can try to find another solution.
Best of luck on your application, and have a great day!!
Ching P.
DAQ and Academic Hardware R&D
(3,551 Views)
thank you for your response... i will try that....
(3,509 Views)
