Disable .NET Deutsch installer inside a LabView application
I have a special issues. I making a LabView Application from LabView2009. Using the setting for use on french Windows XP, I disable all other language (I try with all language too)
I create the Distribution Kit including only LV RT 2009, Advanced Signal Processing Toolkit and DAQmx 8.9.5 (because I use a USB-9211). I Select the Dialog Information language : French. I build the installer (0.98Gb; take around 15 minutes on a Intel Core2 Duo E7500 @2.93GHz, 3G of RAM)
After those step, I go on a brand new Windows XP (in French). Noting install. I transfer the Volume directory to the C drive
So. the installer will install :
95 packages will be installed.
Voilà! I got .NET Framework in Deutsh and a other one (asia I believe). I can remove the two .NET and everyting will still working. How I can remove those from the installer???
Thank
(3,962 Views)
Hi CFiset,
If you take a look at the NI-DAQmx Readme, it has support for the .NET framework. It's probably because of this that .NET is being installed on your deployment machine.
(3,945 Views)
Thank. But, how I can remove the 330MG  from my installer (25% for someting I don't need)
If I install this on only one pc, this will not be to bad, but in my case, I will install this software over 50 pc...
(3,940 Views)
Accepted by CFiset
Hi CFiset,
Unfortunately, there isn't a way to remove the .NET installation with your current version of the DAQmx driver (8.9.5). If you update your driver to DAQmx 9.0 or higher, you will have the option to include just the core drivers or the full development support. If you select to just install the DAQmx Core Run-time and/or the DAQmx MAX Configuration Support, .NET will not be installed on the target computers.
(3,919 Views)
This work for me
Thank
(3,913 Views)
