Disguised Windows task bar if executable is running.
I configured my vi in such a way that the Windows task bar is disguised while the vi is running. However, after I built an executable with the application builder, the Windows task bar remains visible while the exe is running. Why's that? How can I make the Windows task bar to vanish if the executable is running? I'd like to have the full screen modus, if the program runs.
Peter
Message 1 of 13
(4,990 Views)
Whatdo you mean "configured my vi in such a way that the Windows task bar is disguised"? Did you go into "VI properties" (right click on the vi's icon), select "Window appearance", "Customize" and unchecked the various selections like "window has title bar", etc.? That should remove the toolbar, even in the exe version, although I will check that when I am back on my machine that has the application builder.
Putnam Monroe
Putnam
Certified LabVIEW Developer
LabVIEW Champion
Message 2 of 13
(4,969 Views)
You can programmatically hide the taskbar. Checkout G Toolbox at:
http://gtoolbox.yeah.net
George Zou
Message 3 of 13
(4,962 Views)
Hi Putnam,
yes, you understood correctly. I configured the vi in the "vi properties" menu, as you assumed. If I start the vi, the program behaves as desired, i. e., the Windows task bar is disguised. The executable which I generated using the Application Builder, however, does not hide the task bar when running.
Do you see the same effect on your system?
Peter
Message 4 of 13
(4,955 Views)
I'm not seeing the title bar when I run an exe in which it was removed in configuring the windows appearance. When you are building the application, check the settings under "VI settings" to make sure that they agree with what you configured in the vi itself.
I built a very simple vi and when it runs there is a borderless frontpanel (see attached)
Putnam Monroe
Putnam
LabVIEW Champion
Message 5 of 13
(4,947 Views)
I believe he meant the windows taskbar. You can hide it by calling the windows API (although the attached example only leaves a blank area in its place).
___________________
Try to take over the world!
Message 6 of 13
(4,943 Views)
He does say "Windows taskbar" doesn't he. I wasn't very good at "word problems" in school! Always reading too fast and using my own preconceptions!
PM
Putnam
LabVIEW Champion
Message 7 of 13
(4,938 Views)
I am not sure I understand. Do you want to hide the entire Windows Task bar like in the above example, or do you just want to make it so that the LabVIEW exe doesn't show up in the Task bar while it is running.
If it is the second add this line to your executables ini file.
hiderootwindow=true
Message 8 of 13
(4,926 Views)
I am not sure if I completetly understand your application. If you want to hide the entire windows task bar then use the above example.
However, if you just want it so that the executable doesn't show up in the task bar add this line to the Executables ini file.
hiderootwindow=true
Message 9 of 13
(4,928 Views)
Evan, tst,
the example of tst is very close to that what I am looking for. My desire is very simple: After the PC has been booted by Windows, the executable shall start to run automatically (via Autostart). The user shall not see the Windows task bar. Only the user interface of the executable program shall be visible.
Unfortunately, in the example of tst, the task bar vanishes but leaves a blue stripe at the bottom. How can I maximize the window of the application to the full screen height afterward?
Well, to put it even in simplier words: I want the executable program to run in a "full-screen modus". Nothing shall be visible from Windows behind the scene.
You know all these image browsers like Irfanview. "Enter" yields the full-screen modus, "Esc" brings you back to the view with visible Windows taskbar. Any idea how to do that with LabVIEW?
Have a nice weekend!
Peter
Message 10 of 13
(4,921 Views)
