Display and Save DAQ raw data simultaneously
I am new to LabView. I am trying to make a VI that continuously shows in an indicator or a gauge the value from an analog port from a DAQ, while upon user request, saving certain values of that signal on an array.
I can do each one of the things separately:
-real time displaying in an indicator or a gauge of the raw DAQ analog signal
-saving certain points of raw DAQ analog signal
but when I try to do both i am unsure of where to put the DAQ assistant so that it samples when it needs to.
The attached VI is not working properly but you can see the 2 things I would like to have working in parallel.
Any help is greatly appreciated.
Thank you very much in advance.
(7,461 Views)
Accepted by Gabriel_Torre
Hello Gabriel_Torre
you can use Queues this is a simple way to split the acquisition part from the analyse or display part. This is the same like done in the producer consumer examples from LabVIEW.
I also recommend to set the Samples/Rate to factor 1/10 so the loop runs with 100ms not only every second. Now with this architecture all loops run with 100ms iteration time.
Hope it helps.
best regards
Alexander
(7,447 Views)
Thanks a lot!, that was exactly what I was looking for, now i am looking at the producer consumer examples as you suggested to learn more about queues.
What I am no sure now is how to set the Samples/Rate, you mean using a wait block or filing the queue and working with the enqueue timeout?
Regards
(7,408 Views)
Hello Gabriel_Torre,
you can set this inside the DAQ assistent.
Now if a packet of samples arrive and is written into the queuethen the other loops are event driven and read the values from the queue.
best regards
Alexander
(7,402 Views)
I will try that, thanks a lot.
(7,382 Views)
