Display only "true" values in a table
Hi, the support in this forum is really great, so I hope you can help me with this one:
I'm doing a Min/Max comparison with data I measured before and arranged for an XY graph.
Actually I'm comparing two 1D-Arrays and getting a 1D-Array of boolean as result.
This is ok, but I only want to show the index of the true values.
Anyway, I just want to show the x-values, where the threshold was broken.
Any ideas are welcome!
Message 1 of 10
(3,826 Views)
Hallo Steffen,
you need to create that pseudo-code:
FOR all bits in boolean array
  IF bit(i) THEN add i to output array
NEXT
You need a FOR loop, a shift register, a case structure and a BuildArray node.
In recent LabVIEW versions you only need a FOR loop and select the correct output tunnel mode…
Message 2 of 10
(3,822 Views)
Hey Gerd, thank you for your answer!
I'm not really sure how to program this in labview, but I tried to get in the right direction.
Maybe this is not the right way to get what I want.
Do you know another way to get all the x-values (not the index value), when comparing the y-array with the max-array?
Message 3 of 10
(3,805 Views)
Accepted by SteffenS
Hi Steffen,
not at all:
No need for ArraySize, (RubeGoldberg) boolean comparisons, and placing the build array in the wrong place…
I guess I already mentioned to take all those beginner courses offered by NI.com? This is pretty basic LabVIEW stuff!
Message 4 of 10
(3,801 Views)
I know the syntax, but I have problems to handle these arrays.
Thanks to your help, I could get the actual x-values out of the array!
Message 5 of 10
(3,789 Views)
Hi Steffen,
now you created an even bigger Rube-Goldberg: All that code belongs into one loop!
No need to create an index array first when you can index your Y values directly!
Message 6 of 10
(3,784 Views)
you are right, again! Smiley Happy
Message 7 of 10
(3,769 Views)
I believe you have LV2013. Here is simplified code of GerdW's by using the Conditional Enable terminal option.
Message 8 of 10
(3,744 Views)
Smiley Very Happy
Anand, You forgot somthing here.
May be you were in hurry
Message 9 of 10
(3,732 Views)
Yes 🙂 I should have named it as "Y" and made it a control.
Message 10 of 10
(3,719 Views)
