 wedo
			wedo
			10-09-2009 03:47 PM
I wonder whatever Labview FPGA supports Spartan-3E (1600Kgate) kit?
It's already sypport Sartan-3E (500Kgate) kit.
 prashiit
			prashiit
			10-10-2009 02:49 AM
Yes, Labview fpga supports SPARTAN-3E xc3s500e fg320. But, u have to install driver.
U can download this driver from this link
https://lumen.ni.com/nicif/us/infolvfpgaxilsprtn/content.xhtml
see this link also
http://digital.ni.com/express.nsf/bycode/spartan3e?opendocument〈=en&%2338;node=seminar_US
post ur queries (if u have any)
Prashh
10-10-2009 03:12 AM
I know that Spartan-3E (500Kgate) is sypported!
I'm asking about Spartan-3E (1600Kgate), does it work with the same driver?
 Hueter
			Hueter
			10-12-2009 11:41 AM
 Jakebrake
			Jakebrake
			11-19-2009 12:53 AM
Recently I acquire the Spartan 3E-1600 Development Board.I tried to figure out how to "restructure" the files by modifying the following files in this path: C:\NIFPGA86\Xilinx\spartan3e\data - xc3s500e.bsd ---> xc3s1600e.bsd- 3s500e.xxx ---> 3s1600e.xxxI succeeded in the first compiling stage , but still having problems when is recognizing the component ID (from 29499539----> 3E500 to 29597843---->3E1600), of course I change the binary ID tags without the required result. I observed that it has something to do with the 3sXXXe.nph file but as it is encrypted there is no way to modify it.I suppose that develop a driver for the other board wont be too much problem. Already sent a product suggestion, but I assume it will take long to obtain it. There is some walk-around for this?
 Hueter
			Hueter
			11-19-2009 07:36 PM
 basel.srouji
			basel.srouji
			11-29-2010 07:05 PM
 the USAMA
			the USAMA
			01-03-2011 10:21 PM
hello dear,
If you can tell me how i can use Spartan-3E (1600Kgate) kit with labveiw I SHALL BE VERY THANK FULL FOR YOUR ANSWER
 charris
			charris
			01-04-2011 11:40 AM
Unfortunately, the 1600Kgate Spartan-3E is not currently supported. As Hueter mentioned, the fastest way to be heard on this issue is to submit a product suggestion (you can do so here).
 1105
			1105
			06-14-2013 04:04 AM
I hae labview vi.now i want to create labview fpga vi and would like to port it on xilinx virtex 4 fpga.when i open the project explorer and adding target and devices there is no fpga target. what should i do?
