Double Indicator time
Hi guys,
I have a problem.
I want  to display an double indicator, where MMM,ss format . I get minutes value separately and seconds value separately..
Boldness has genius, power and magic in it!'
(4,301 Views)
You can use the Timestamp indicator to display information in the requested layout. When displaying numeric values as timestamps, you have to convert them first using the "To Timestamp" function.
Please note that with that conversion, the timestamp starts from 1/1/1904 00:00:00 for the value '0'.
Norbert
EDIT: Using the Display Format option of numeric indicators, you can configure them to display time and date as well. Please check this option.
Norbert
Expert: Geometry
(4,290 Views)
Hi Maveen,
when you get those values seperately you should combine them:
Using a description like "double" isn't very descriptive as this also denotes a basic LabVIEW datatype...
(4,280 Views)
Accepted by MaveenD
Something like this?
EDIT:  Just noticed that you said you get Minutes and Seconds separately.  GerdW has the answer you want then.
(4,261 Views)
Hi Maveen,
you can easily get "t=minutes+60*seconds" to use crossrulz' suggestion. One way or the other, whichever fits better...
(4,248 Views)
