Doubt in process "Installer"
After of the I can tried this way, verifically which not unnistall this drivers. When I install, is created a directory that name, which not is order to creat.
Maybe this creating anything in root of the systm of the machine, that I can't eliminated.
Sorry this launguage,
Regards.
Hugo Santos
Student at ISEC - Master Mechanical Equipment and Systems
Message 11 of 15
(540 Views)
Hugo, I am really sorry but i don't understand what you explained. Could you try again please?
Best regards
Romain DUVAL || RF & Semiconductor Staff System Engineer || CLA || CTA
National Instruments France
Message 12 of 15
(528 Views)
Have solved the previous problem, now for the executable appears an error on the machine that was installed excultavel. Will the problem referenced in Annex.
Greetings.
Hugo Santos
Message 13 of 15
(523 Views)
Hi Hugo,
Is the reference stored in an FGV or more generally in a shift register?
Could you eventually share the part of the code generating this error?
One thing you can try to workaround is to reopen the reference if it is not valid. Here is a simple VI to do so:exemple.png
Message 14 of 15
(513 Views)
Hi Romain, thanks for your reply.
I will test this way, and leave attached the code that is displaying the error.
Hugo Santos
Message 15 of 15
(507 Views)
