06-21-2012 08:25 AM
After of the I can tried this way, verifically which not unnistall this drivers. When I install, is created a directory that name, which not is order to creat.
Maybe this creating anything in root of the systm of the machine, that I can't eliminated.
Sorry this launguage,
Regards.
 Romain_Duval
			Romain_Duval
			06-21-2012 09:56 AM
Hugo, I am really sorry but i don't understand what you explained. Could you try again please?
Best regards
Romain DUVAL || RF & Semiconductor Staff System Engineer || CLA || CTA
National Instruments France
06-21-2012 10:26 AM
Have solved the previous problem, now for the executable appears an error on the machine that was installed excultavel. Will the problem referenced in Annex.
Greetings.
 Romain_Duval
			Romain_Duval
			06-22-2012 02:59 AM
Hi Hugo,
Is the reference stored in an FGV or more generally in a shift register?
Could you eventually share the part of the code generating this error?
One thing you can try to workaround is to reopen the reference if it is not valid. Here is a simple VI to do so:
06-25-2012 03:50 AM
Hi Romain, thanks for your reply.
I will test this way, and leave attached the code that is displaying the error.
