Downconvert VI Requests
@TimColo wrote:
I would like to get all of these VIs downconverted from Labview 8.0 to LabView 6.0.
All needed VIs are linked to Cond_5c.vi.
Thank you for your help.
-tim
Attached is the code in 6.0. I received numerous front panel insane object errors related to the XY graphs. You should replace the graphs with new ones. You will also need to correct one of the subVIs since the Open File functions in earlier versions of LabVIEW did not have the output that's being used by the 8.0 code.
Message 321 of 1,444
(1,595 Views)
Thank You. Thank You. Thank You.
Message 322 of 1,444
(1,591 Views)
Oh.. Ok Thank you.
I have another Labview file. Help me, please.
Message 323 of 1,444
(1,580 Views)
Could I possibly get this vi converted to LV2009?
Thank you very much,
Arthur J.
Message 324 of 1,444
(1,602 Views)
Arthur J.
in LV2009...
Message 325 of 1,444
(1,559 Views)
@hank14 wrote:
Oh.. Ok Thank you.
I assumed that based on your previous requests you wanted 7.1.
Message 326 of 1,444
(1,550 Views)
Oh smercurio_fc, Thank you very much.!!
Message 327 of 1,444
(1,533 Views)
Can anyone please convert this from LV 9.0 to LV8 8.0 ???
Now on LabVIEW 10.0 on Win7
Message 328 of 1,444
(1,521 Views)
Not sure if this will work...
Message 329 of 1,444
(1,511 Views)
again to LV 8.0/??? please
Message 330 of 1,444
(1,483 Views)
