Downconvert VI Requests
Hi,  I too would like to appeal if some helpful soul can assist with a downconversion.
I'm using a US-Digital encoder data acquisistion card.  They have been able to provide me with a .lib containing 109 vi's.  They are all small vi's containing a function call.
I've got it converted from 8.6 to 8.0, but now need to get it back to 7.1.  I've really tried to get hold of LV8.0 with no luck.  Is anyone willing to asist me? (I'm really not keen on the idea of re-coding 109 function calls).
Thanks in advance.
Message 521 of 1,444
(1,949 Views)
Hi s class,
first you should make a "Tree.vi" which contains all of those 109 small VIs. Then you should attach the tree.vi with all it's subVIs in a ZIP file. Then someone will be glad to help you...
Message 522 of 1,444
(1,947 Views)
Thank you for your help, GerdW.
attached is a ZIP containing a top level vi (tree) with all the 109 subvi's in it.  The ZIP also contains the 109 subvi's, and the relevant DLL.
It is currently in version 8.0, and if someone can convert it back to 7.1, I would be very grateful.
Thanks, Ryan
Message 523 of 1,444
(1,933 Views)
Hi All,
Please down grade this LabVIEW 10 VI to LabVIEW 9 VI.
Thk you,
Ram
Message 524 of 1,444
(1,920 Views)
Thanks, Ryan
Attached should be in 7.1
Message 525 of 1,444
(1,906 Views)
@Ramsgt wrote:
Hi All,
Thk you,
Ram
The custom control was not included so I disconnected the two instances of it from the typedef. While it may be pretty on the front panel, I despise any program that has an infinite loop, requiring one to use the Abort button to actually stop the program.
Message 526 of 1,444
(1,894 Views)
Can you please convert the following vi from 2009 version to 8.6 version ?
Message 527 of 1,444
(1,878 Views)
Can someone help me convert my Labview 2010 VI file to Labview 2009 compatible? Thanks! Smiley Happy
Message 528 of 1,444
(1,871 Views)
here it is...
Message 529 of 1,444
(1,864 Views)
Thanks, Ryan
Thank you very much, my app is up and running in ver 7.1.  Much appreciated.
Message 530 of 1,444
(1,862 Views)
