Downconvert VI Requests
Working on it now....I'll edit this post once I'm finished doing the downconvert.
Message 901 of 1,444
(2,078 Views)
Thanks for your attention and awaiting the downconvert.
               L
Message 902 of 1,444
(2,068 Views)
Sorry it's taking me so long to get back with this.  I'm running into a lot of problems downconverting these VIs.  It's possibly related to a file being missing.  Many of these VIs are looking for the file "CCS_Series_Drv_32.dll."  Do you have this file on hand?
Message 903 of 1,444
(2,050 Views)
Strange, since I do not get that error message. All I can think to do is upload an earlier version of the program which I hope will contain the relavent file.
Thanks for your efforts so far.
             L
Message 904 of 1,444
(2,039 Views)
Can someone help me to convert these vi's from ver. 8.6 to ver 8.5? Apparently, they require IMAQ in order to convert them.
Message 905 of 1,444
(2,026 Views)
             L
The DLL would not be contained inside of a LabVIEW library. If it's not in the director, then it's in your operating system's system folders. On Windows the DLL would most likely be in C:\Windows\system32.
Normally the DLL isn't required in order to do a downconvert. However, sometimes LabVIEW has a problem in down-converting VIs that use the CLFN (and also with some typedefs). I also tried to downconvert, and LabVIEW kept crashing.
Message 906 of 1,444
(2,015 Views)
Can someone please help me to down convert the VIs from Labview 2010 to Labview 2009....
Thanx.....
Message 907 of 1,444
(2,011 Views)
Have the Design Pattern VIs been down-converted before?  I was wondering if this could be down-converted to LV 7.1 (source is LV 10)
Thank you in advance!
Bob Seegmiller
NG UMS Ryan Aeronautical Center
Message 908 of 1,444
(2,004 Views)
Thanx.....
here ya go
Message 909 of 1,444
(1,997 Views)
Only one small example was previously done. Not sure if the attached will work for you. Since projects don't exist in LV 7.1 I had to create a VI and put all the VIs and controls on it in order to downconvert everything.
Message 910 of 1,444
(1,993 Views)
