Downconvert VI Requests
@UofA6809 wrote:
I am working in Labview 6 (nessasary as some of my equiptment requires a very old computer to run) and need a downconversion for the following files to an Ocean Optics USB2000 spectrometer.  Any assistance would be super useful and appriciated.
Were you actually trying to get the library downconverted? If so, you need to upload the actual VIs that comprise the library. The .lvlib file is just the XML file that defines what files are in the library.
Message 1271 of 1,444
(1,707 Views)
I didn't mean to upload that file.  It is the other two I need downconverted.  They will have all the subvi's I need.
Message 1272 of 1,444
(1,706 Views)
Hi Pauli,
no, those VI don't have any subVIs included.
SubVIs are never included in other (main)VIs, they always reside as separate files on your harddisc...
Message 1273 of 1,444
(1,697 Views)
Well then I just need the 2 vi's down converted.  They will do everything I need to do.
Kevin Lyon
Message 1274 of 1,444
(1,695 Views)
I am trying to allocate Windows Memory for a Counter function in LabView 7.1.  Could someone Please convert these from Ver. 8.0 to Ver. 7.1
Message 1275 of 1,444
(1,693 Views)
Need these three Vi's Downconverted to Labview 6 if possible
Thanks, Kevin
Message 1276 of 1,444
(1,704 Views)
Everyone can dissregard the previous post.
I attempted to run around the department and back convert this myself.  I have run into a wall.  I have the tree back converted all the way down to version 7.0 but I can't find anyone with a previous version to get me to version 6.0.  If anyone could take this tree vi and down convert it to version 6.0 I would be super, uber, awsome, grateful.
Kevin Lyon
Message 1277 of 1,444
(1,691 Views)
Here is a zip containing your downconvert to 7.1
Kevin
Message 1278 of 1,444
(1,687 Views)
I need the example "Measuring Angular Position with myDAQ and Sparkfun IDG500 Dual Axis Gyroscope Breakout Board"  converted down to version 8.6, i also attach the vi.
Many thanks
/Torsten
Message 1279 of 1,444
(1,677 Views)
Hi Torsten,
it's missing a typedef, but I think you can cope with it...
Message 1280 of 1,444
(1,668 Views)
