Downconvert VI Requests
Could someone please downconvert these VIs for me?
source LabVIEW version 9.0
target LabVIEW version 8.6
Cheers!
Message 231 of 1,444
(2,715 Views)
One more
Message 232 of 1,444
(2,713 Views)
There are many subVIs missing, as well as at least one typedef. Are you sure you still want it converted as you posted it?
P.S. Whoever came up with the naming scheme of using "sub" in front of the VI names or using framework names as folder names (i.e., "Action Engines" as a folder name) was just silly.
Message 233 of 1,444
(2,703 Views)
Thank you for the swift reply!
Ah yes, now I see that there are quite a few more (bluetooth) subVIs.
Might actually be a bit too much to ask. If you're curious though, I got it from this page.
http://decibel.ni.com/content/docs/DOC-10643
Speaker Example.zip (407.6 K)
Message 234 of 1,444
(2,696 Views)
OK. Attached is the Speaker Example in 8.6. Still missing a VI, though it appears to be used by a VI that's not even used in "Main.vi".
Message 235 of 1,444
(2,688 Views)
Appreciate it!
Message 236 of 1,444
(2,680 Views)
Hi all! I am working on USB micro's U421 USB interface. I found the following VIs on the internet, which are very useful to my project. But, they are in LabView 8.2.1, whereas I have a licensed version of LabView 7.1. I would be really grateful to you if anyone can please convert the VIs in the following attachment into LabView 7.1 VIs.
Message 237 of 1,444
(2,640 Views)
Attached is in 7.1.
Message 238 of 1,444
(2,616 Views)
Hey guys,
I need 2 files converted from LabView 2009 to version 7.1. Can someone do it for me? Thanks a lot.
Cheers,
Andrey
Message 239 of 1,444
(2,564 Views)
I have no idea if these will work for you. You did not include several subVIs (from a KE6485 library and one called "Return code insertion").
Message 240 of 1,444
(2,551 Views)
