Downconvert VI Requests
Thanks a lot. these two files look fine but you are right i still need one more file converted. can u do that for me as well. the file is attached.
Message 241 of 1,444
(2,254 Views)
Hi ARay,
here's ReturnCodeInsertion:
19673i3B1BFB504368765C
In the False case the error is just wired through...
Message 242 of 1,444
(2,247 Views)
Hi can someone pl. convert this 9.0 file to 8.5 pl.
thanks in advance...
Message 243 of 1,444
(2,240 Views)
Attached is the VI in 8.5.
WARNING: It appears the VI was written so that the Run Continuously button has to be used. THIS IS BAD. There should be a loop as the main construct. The serial port initialization and close should be outside the loop with everything else inside. Look at the "Advanced Serial Write and Read" example that ships with LabVIEW for how it should be done.
Message 244 of 1,444
(2,236 Views)
Hey buddy...
Thanx a ton for the conversion... Can u pl. help on that warning... I have no idea even after seeing the example.
Message 245 of 1,444
(2,229 Views)
See attached modification. Note that I did not wire up for the errors with the VISA Writes. I'll let you do that.
Message 246 of 1,444
(2,215 Views)
Thanks a lot. that helped me pretty much 🙂
Message 247 of 1,444
(2,200 Views)
The original version is 9.0 can i get it converted to 7.1. Thanks all.
Message 248 of 1,444
(2,182 Views)
Has anyone had a change to try to downconvert my file from version 9.0 to 7.1? The attachment is above. Thanks.
Message 249 of 1,444
(2,131 Views)
try the attached
Message 250 of 1,444
(2,122 Views)
