Downconvert VI Requests
Hello, I'd like to request a downconversion of the attached VI, originally from here: http://decibel.ni.com/content/docs/DOC-4765.
Thank you very much
Message 261 of 1,444
(2,134 Views)
Hi FiberOptix,
and what do you need?
Message 262 of 1,444
(2,130 Views)
I'd like the labview 8.6 VI contained within downconverted to 8.5 please.
Message 263 of 1,444
(2,122 Views)
Attached should be in 8.5.
Message 264 of 1,444
(2,110 Views)
Thank you.
Message 265 of 1,444
(2,103 Views)
Hi All,
I've obtained a driver for a Keithley 2612A for LabView 8 or above (attached).  Would it be possible to convert this to work with LabView 7.1?
Many thanks!
John
EDIT: It seems I misunderstood the use of the word "Driver" in this instance.  I thought this file (files, rather) was necessary for me to use the instrument, but it turns out that this is a collection of sample VIs.  I may ask for a few of these to be converted in the future, but I won't ask anyone to convert them all for me.  Sorry for the false alarm, I'll resubmit my request if I have specific VIs I need converted.
Message 266 of 1,444
(2,081 Views)
It is a driver in the LabVIEW sense. Unless you want to write all of the code to communicate to the instrument, your really do want this converted. However, if you are comfortable with the VISA functions and with the commands in the programming manual, then you can skip using the code.
Message 267 of 1,444
(2,071 Views)
I have a couple of vi's version 9 which i need to convert to 8.6 very badly can someone help me please. I have attched the attached the vi's  I need it converted to 8.6 please help!!!!
Cheers
Message 268 of 1,444
(2,028 Views)
hi  I too have a couple of vi's in LV 9 that i need to be down converted to 8.6 . Is there any way i can do so??
i will attach a few. Please help me if you can!!!!
Cheers
Message 269 of 1,444
(2,017 Views)
Hi, Can someone downconvert this file to version 7.1 or lower
Message 270 of 1,444
(2,000 Views)
