Downconvert VI Requests
Hi all,
I'm trying to programmatically read a GIF and draw it to my front panel using LV6.1. I've found the solution here, but it is in 7.1 format. Is there anyone who has this in 6.1 or can convert?
Thanks!
-Cameron
Message 271 of 1,444
(3,264 Views)
@viCam wrote:
Hi all,
Slight problem: The image functions in LabVIEW 6.1 are different than the ones in 7.1, and even after converting it, LabVIEW 6.1 crashes when loading the core VI.  Doesn't look like something that can be back-saved.
Message 272 of 1,444
(3,258 Views)
Hi
Could anyone help me out with this? It's 2 files in LV9.0 which I need converted to LV7.1
Bruce
Message 273 of 1,444
(3,244 Views)
Thanks smercurio for trying. I'll just have to pay up $30 bucks for George Zou's software. Sigh...
Message 274 of 1,444
(3,236 Views)
knight2,
Try these files out. Have a great weekend : )
Stephanie A.
Americas Marketing Manager
Message 275 of 1,444
(3,217 Views)
Hi all,
i've an older registered version of Labview 7.1 and i need to interface the R&S SFU 10 and R&S SFE 100 digital signal generator. Unfortunetly, on R&S site is available only the Labview 8.2 drivers version for these instruments and i'm not able to use the VI's with my 7.1.
Can someone kindly help me to downconvert it to the 7.1 version? (with priority for SFU 10 instrument)
Sorry if I attach the links and not directly the drivers files, but they are too big to be posted here:
SFU 10: http://www2.rohde-schwarz.com/en/products/broadcasting/broadcasting_measurement/SFU-%7C-Drivers-%7C-...
SFE 100: http://www2.rohde-schwarz.com/en/products/test_and_measurement/video_tv/analog_modulation/SFE100-%7C...
Or, if someone knows a way i can try (i'm not very expert) to downconvert them i can do it by myself.
Thank you very much for your help and your interest.
Giorgio
Message 276 of 1,444
(3,183 Views)
@Giorgio: To convert to 7.1 you need a copy of LabVIEW 8.0. These can be downconverted, but they will still be too large to post here (and will actually be larger than the original), so where can we even put them?
Message 277 of 1,444
(3,169 Views)
@ smercurio_fc: Thank You for your kind reply. If you want we can use a free internet files repository (you can register for free only putting your mail address). I've just uploaded the two drivers files on it.
                         This are the links where you can download them:
                         RSSFU 8.2 drivers: http://www.4shared.com/file/lmnIUeDg/rssfu_lv82_2_20_0.html
                         RSSFE 8.2 drivers: http://www.4shared.com/file/3g7h_JM6/rssfe_lv82_2_20_0.html
                         I hope i can post these external links, if not sorry for that.
                         If you want you can re-upload the converted drivers on 4shared.
                         Thank You very much for your support and time!
Ciao
Giorgio
Message 278 of 1,444
(3,157 Views)
Actually, I just used 7-Zip and the compressed file is within the limits of attachments here.
Message 279 of 1,444
(3,129 Views)
Message 280 of 1,444
(3,128 Views)
