Downconvert VI Requests
Hello smercurio_fc,
thank you very much another time! 😉
Ciao
Giorgio
Message 281 of 1,444
(1,851 Views)
Can I get this downconverted to 7.1 please?
And thank you so much to whoever does it 🙂
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=6E23DB10D9FC2B05E04400144FB7D2...
Message 282 of 1,444
(1,841 Views)
Have you tried the 7.1 version?
Message 283 of 1,444
(1,829 Views)
Hi
Please could I have some help getting this into 8.0.
Kind Regards
Kind Regards
Christopher Roberts
Message 284 of 1,444
(1,807 Views)
@christopher Roberts wrote:
Hi
Kind Regards
Try the attached.   WARNING: The "Memmert_LabVIEW_driver_01" archive contains a VI that for some reason uses .NET to interface to the serial port. This seems really silly to me, as VISA is available to be used in LabVIEW.
Message 285 of 1,444
(1,796 Views)
Thanks very much
I'd also prefer to run with VISA, but couldn't even open it in 8.0.
Kind Regards
Christopher
Kind Regards
Christopher Roberts
Message 286 of 1,444
(1,795 Views)
I have, I think there might be more in the other version though, but I can't open it to find out. The links make it seem like the other version has more.
Also, the other versions are 4.2, whereas the 7.1 version is 3.1
Message 287 of 1,444
(1,789 Views)
OK, here's the downconverted version. Not sure if everything is actually in there, since projects did not exist in LabVIEW 7.1, so there's no simple way to downconvert a project to 7.1. There was a "VI Tree" VI in there so I used that.
Message 288 of 1,444
(1,766 Views)
Thank you very much 🙂
Message 289 of 1,444
(1,762 Views)
Hello can anyone please convert the file from Labview 9.0 to labview 8.0??? I have an example that is written in lv 9.0 but i have only lv 8.0
Please check the attachments... it is one of the programs that has written.... how to display a certain number of graphs on the display through DAQmx input ...
Now on LabVIEW 10.0 on Win7
Message 290 of 1,444
(1,720 Views)
