09-13-2010 03:00 PM
@TimColo wrote:
I would like to get all of these VIs downconverted from Labview 8.0 to LabView 6.0.
All needed VIs are linked to Cond_5c.vi.
Thank you for your help.
-tim
Attached is the code in 6.0. I received numerous front panel insane object errors related to the XY graphs. You should replace the graphs with new ones. You will also need to correct one of the subVIs since the Open File functions in earlier versions of LabVIEW did not have the output that's being used by the 8.0 code.
09-13-2010 03:05 PM
Thank You. Thank You. Thank You.
09-13-2010 09:31 PM
Oh.. Ok Thank you.
I have another Labview file. Help me, please.
09-14-2010 02:40 AM
Could I possibly get this vi converted to LV2009?
Thank you very much,
Arthur J.
09-14-2010 09:25 AM
Arthur J.
in LV2009...
09-14-2010 09:30 AM
@hank14 wrote:
Oh.. Ok Thank you.
I assumed that based on your previous requests you wanted 7.1.
09-14-2010 08:36 PM
Oh smercurio_fc, Thank you very much.!!
09-15-2010 09:23 AM
Can anyone please convert this from LV 9.0 to LV8 8.0 ???
09-15-2010 01:10 PM
Not sure if this will work...
09-16-2010 04:11 PM
again to LV 8.0/??? please
