Downconvert VI Requests
Could you help me anybody? I want to downconvert this lv8.5 to lv8.0.
Please help me.
Message 341 of 1,444
(2,039 Views)
Can I get the following vi converted from 8.6 to 7.1
Message 342 of 1,444
(2,026 Views)
Please help me.
Attached ...
Message 343 of 1,444
(2,015 Views)
You are missing all of the subVIs (about 34 of them), so the top-level VI won't do you much good. Still want it converted? If not, please post all of the code.
Message 344 of 1,444
(2,014 Views)
Could someone downconvert this from 8.6 to 7.1?
It should be attached and is from this thread:
http://forums.ni.com/t5/LabVIEW/csv-with-double-quotes/m-p/1252952#M527290
Thank you.
LabVIEW user since 2.0
Message 345 of 1,444
(2,007 Views)
Hi Nimble,
LV7.1!
Message 346 of 1,444
(2,006 Views)
hi can u please convert this ecg heart rate reduction and qrs detection and signal conversion (which is in labview 9.0 to labview 8.5 ) urgent please
will be very happy if u do so
Message 347 of 1,444
(1,969 Views)
Attached is in 8.5.
WARNING: The code has some dubious/incorrect coding:
  • In the "SC1" VI the sequence structure is useless.
  • In the "heart rate" VI :
    • there is a Stop button inside the for-loop that has no functionality.
    • there is a Prompt Dialog that is not tied to anything, and there's a separate control for entering the "r-r interval"
    • the for-loop is forced to run 25000 times, regardless of the size of the array
  • In the "ecg" VI:
    • the for-loop is being auto-indexed and hard-wired at the same time. This is not correct. Do one or the other, not both.
    • the "true Array 4" and the graph are using the last iteration of the for-loop as the array value. This is not correct, as you should be using the shift register.
    • the for-loop can be completely replaced with a single "In Range and Coerce" function.
There's probably more, but that's all that I looked at.
Message 348 of 1,444
(1,962 Views)
can u please boss convert it to labview 8.5 ... i know the sequence structure is useless and r-r interval is not required and there is no need for stop button and all. i need it boss very very urgent.... can u please please convert it
Message 349 of 1,444
(1,953 Views)
please can anyone convert it for me .. please ppl ... i need it for my project evaluation marks... or else i ll flunk in the paper .. please help me
Message 350 of 1,444
(1,938 Views)
