Downconvert VI Requests
@Upconvert VI Requests wrote:
please can anyone convert it for me .. please ppl ... i need it for my project evaluation marks... or else i ll flunk in the paper .. please help me
Sorry. I had done the conversion but forgot the attachment.
Please be aware that this forum is primarily made up of volunteers who, like me, have full-time jobs and we cannot respond to queries at the drop of a hat. If you need immediate assistance then you should contact NI support directly.
Message 351 of 1,444
(1,584 Views)
This is not so much a request for a downconvert as it is a request for info on doing it en masse.
I have a very large project that I decided to bring up to 2010. I did a mass compile and everything worked fine until I hit some vi's that use a custom driver library from Andor, a camera manufacturer. When I run these vi's they run once fine and then crash LabVIEW.
So I want to go back to 2009. I have saved most of the vi's in backups as 2009 but have converted about thirty of them to 2010. Is there a way to do a mass compile back to an earlier version or at least the equivalent of that. Can this be scripted? Open, save as version X, repeat etc.
Any info would be greatly appreciated.
Dave
David A. Taylor
Message 352 of 1,444
(1,569 Views)
First, let me get the "you should be using a source code control system so you wouldn't have this problem" speech out of the way. You should be using a source code control system so you wouldn't have this problem. This would allow you to have a backup of everything.
Now, to your question: you can put all the VIs into a project and then do a Save for Previous Version or you can put all the VIs on the block diagram of a new VI and do a Save for Previous Version.
Message 353 of 1,444
(1,566 Views)
I hear you loud and clear on the version control. I got pretty sloppy.
Thanks for the great tips. That is just what I was looking for.
David A. Taylor
Message 354 of 1,444
(1,554 Views)
Hello all,
 While converting a code (with just an event structure) from LV 2009 to 8.2 ,it thown an Error (attached as an Image). Some time back, I saw a post in this forum where they argued that  it is not possible to convert the Code  from LV 2009 to 8.2 which contains an event structure, also,  to do this is to convert it to LV8.6, open in LV.8.6 and convert to 8.2. I tried this and it is worked, but  I have to automate this process, so is there any other way to do directly convert from LV 2009 to LV 8.2 ?
AshwiN,
Message 355 of 1,444
(1,528 Views)
Source labview 8.5
target labview 7.0
Can you please convert these 8.5 files to labview 7.0
Best regards and thanks in advance
Thijs Boeree
Message 356 of 1,444
(1,519 Views)
@ThijsBoeree wrote:
Source labview 8.5
target labview 7.0
Try the attached. There were a number of VIs missing. Some were from Traditional DAQ, so you can just install that. Others were custom VIs which were not in the archive.
Message 357 of 1,444
(1,509 Views)
@Ashwin S wrote:
Hello all,
AshwiN,
Are you using LV 2009 or LV 2009 service pack 1?
If you can upgrade to SP1 then you won't have a problem back saving to an older version lf LV if you have an event structure.
See LabVIEW 2009 Service Pack 1 Bug Fixes for CAR 183005.
Message 358 of 1,444
(1,501 Views)
I want to go from 8.0 to 7.1 with all three files.
Thanks you very much!
Message 359 of 1,444
(1,493 Views)
Can some one convert this to labview 7.1 Because this attachment is labview 9. Thanks!
Message 360 of 1,444
(1,470 Views)
