Downconvert VI Requests
THANKS !
Message 411 of 1,444
(1,570 Views)
Is it possible to downconvert something from the Open G Toolkit?  They seem to be at 8.2.1.
There a file-time modification utility in the file.llb that we would need at 7.1
Bob Seegmiller
NG UMS Ryan Aeronautical Center
Message 412 of 1,444
(1,558 Views)
The OpenG packages are distributed most easily using the VI Package Manager. With that you can install previous versions. The previous version of that library is compiled for LabVIEW 6. Thus, it's probably easier just to do that.
Message 413 of 1,444
(1,552 Views)
Thanks -- most helpful!!!
Bob Seegmiller
Message 414 of 1,444
(1,550 Views)
Dear NI,
I have a Labview 6.1 and I wish to control a Agilent E3645A Power Source, however I can't find any driver wich works at this version. Can you provide them?
Here is the 7.1 driver, which does not work.
Message 415 of 1,444
(1,530 Views)
@Alysson wrote:
Dear NI,
Attached is the library in 6.1
Message 416 of 1,444
(1,523 Views)
Could you please convert the attached vi to Labview2009 version. Thanks.
V.Roth
Message 417 of 1,444
(1,513 Views)
Hello
Can I have this IV (version 8.6) in 8.5 version ?
Thanks a lot.
Julien
Message 418 of 1,444
(1,508 Views)
Thanks. It realy stopped the compatibility problem. However, I'm not able to delete a function, or even to access the Diagrams. Is it other compatibility problem?
Message 419 of 1,444
(1,498 Views)
I do not understand what you are saying or asking. I am able to open the library I attached with LabVIEW 6.1 without any issues, and I can see the block diagrams of each VI. I do not understand what you mean by "not able to delete a function".
Message 420 of 1,444
(1,493 Views)
