Downconvert VI Requests
Hi modobrofo,
here you go...
Message 511 of 1,444
(1,882 Views)
Hello all,
My team is in a bind and we need a down conversion from 8.6 to 8.5.1.
Thank you very much.
Message 512 of 1,444
(1,866 Views)
@Dmip wrote:
Could someone please convert the attached examples and design templates from Blume's "The LabVIEW Style Book" from LV 8.2.1 to LV 7.1?
I would appreciate your help.
Not sure if these will work for you since LabVIEW 7.1 lacked a number of features that LV 8.2.1 has, such as libraries and projects...
Message 513 of 1,444
(1,839 Views)
@grapalo wrote:
Hello all,
I was unable to back-save Normal Volt. LabVIEW thinks the VI is from a toolkit. Where did you get the VI?
Message 514 of 1,444
(1,828 Views)
Could you please help me downconvert from Labview 9.0 file to an 8.0 ?
I am trying to open this file, and the error is "VI version is later than the current LabView version"
Thanks!!!
Message 515 of 1,444
(1,826 Views)
Thanks!!!
See attached
Message 516 of 1,444
(1,821 Views)
Mercurio, thank you very much for the prompt reply!
Would it be possible to do the same with this file (downconvert from 9.0 to 8.0)?
Many Thanks!!!
Message 517 of 1,444
(1,817 Views)
Many Thanks!!!
You're missing the "bit array converter" VI.
Message 518 of 1,444
(1,808 Views)
I found them on a google search at http://sites.google.com/site/team5spirometer/labview-programming for a biopac/labview interface.  I got the VI you sent back to open, but it has a lot of problems and the DAQmx Control Task VI is unable to find some pieces. Also I am not too sure what the other vi does for it.  Any help is appreciated.
Message 519 of 1,444
(1,795 Views)
Great! Thank you so much, smercurio_fc!
Message 520 of 1,444
(1,786 Views)
