12-03-2010 09:10 AM
Hi, I too would like to appeal if some helpful soul can assist with a downconversion.
I'm using a US-Digital encoder data acquisistion card. They have been able to provide me with a .lib containing 109 vi's. They are all small vi's containing a function call.
I've got it converted from 8.6 to 8.0, but now need to get it back to 7.1. I've really tried to get hold of LV8.0 with no luck. Is anyone willing to asist me? (I'm really not keen on the idea of re-coding 109 function calls).
Thanks in advance.
12-03-2010 09:15 AM
12-06-2010 03:30 AM
Thank you for your help, GerdW.
attached is a ZIP containing a top level vi (tree) with all the 109 subvi's in it. The ZIP also contains the 109 subvi's, and the relevant DLL.
It is currently in version 8.0, and if someone can convert it back to 7.1, I would be very grateful.
Thanks, Ryan
12-06-2010 05:17 AM
Hi All,
Please down grade this LabVIEW 10 VI to LabVIEW 9 VI.
Thk you,
Ram
12-06-2010 09:36 AM
Thanks, Ryan
Attached should be in 7.1
12-07-2010 08:32 AM
@Ramsgt wrote:
Hi All,
Thk you,
Ram
The custom control was not included so I disconnected the two instances of it from the typedef. While it may be pretty on the front panel, I despise any program that has an infinite loop, requiring one to use the Abort button to actually stop the program.
12-08-2010 03:39 AM
Can you please convert the following vi from 2009 version to 8.6 version ?
12-08-2010 04:38 AM
Can someone help me convert my Labview 2010 VI file to Labview 2009 compatible? Thanks!
12-08-2010 04:52 AM
12-08-2010 05:03 AM
Thanks, Ryan
Thank you very much, my app is up and running in ver 7.1. Much appreciated.
