Downconvert VI Requests
This is the first time I'm using this relatively new and great forum, so please be patient if I make errors.
Could someone please downconvert the attached vi from version 8.6 to 8.5.
Thank you very much.
Ed
Message 611 of 1,444
(1,867 Views)
Hi Edjsch,
here it is...
Message 612 of 1,444
(1,857 Views)
Thank you so much. Kudos to you.
Ed
Message 613 of 1,444
(1,845 Views)
Could you convert these labview 8.6 file to labview 8.5?
thanks
Message 614 of 1,444
(1,832 Views)
thanks
Try the attached...
Message 615 of 1,444
(1,828 Views)
Could someone help in converting the following labview files into version 8.5.
These are solutions to the CLD exam samples and you would be helping me a lot.
Greatly appreciated!
Message 616 of 1,444
(1,800 Views)
Can someone backsave these XControl project files from 8.6 to 8.6 for me?  Backstory is I saved them in 8.6.1f3 since I had that for the FIRST robotics team I mentor, and then I couldn't open them in 8.6.1f1 at work.  Only my project files wouldn't open.  Everything else was fine for some reason?
Tim Elsey
Certified LabVIEW Architect
Message 617 of 1,444
(1,781 Views)
What you posted is merely the XML file that defines the XControl. None of the VIs are there that actually make up the XControl.
Message 618 of 1,444
(1,771 Views)
See attached.
Message 619 of 1,444
(1,770 Views)
I know.  Those are the only files I can't open.  I can open all of the VIs individually.  But, I can't open the project or drop the xcontrol because it's in a newer version.
I successfully opened an actual projects xml and manually changed the LVVersion, but it didn't work for the XControl.
Tim Elsey
Message 620 of 1,444
(1,762 Views)
