Downconvert VI Requests
@elset191 wrote:
@smercurio_fc wrote:
@elset191 wrote:
Can someone backsave these XControl project files from 8.6 to 8.6 for me?  Backstory is I saved them in 8.6.1f3 since I had that for the FIRST robotics team I mentor, and then I couldn't open them in 8.6.1f1 at work.  Only my project files wouldn't open.  Everything else was fine for some reason?
What you posted is merely the XML file that defines the XControl. None of the VIs are there that actually make up the XControl.
I know.  Those are the only files I can't open.  I can open all of the VIs individually.  But, I can't open the project or drop the xcontrol because it's in a newer version.
I successfully opened an actual projects xml and manually changed the LVVersion, but it didn't work for the XControl.
Ugh, it didn't work because I typed the wrong number.  Sorry for the clutter.
Tim Elsey
Certified LabVIEW Architect
Message 621 of 1,444
(1,857 Views)
Dear All,
Can any one convert these Labview 2009 vi  file to Labview 7.1 vi compatible with windows xp .
Thanks in advance
Message 622 of 1,444
(1,848 Views)
Can any one convert this Labview 2009  vi file into Labview 7.1
Thanks in advance
Message 623 of 1,444
(1,848 Views)
Need attached as LV 8.5
Thanks.
Gurdas Sandhu, Ph.D.
ORISE Research Fellow at US EPA
Message 624 of 1,444
(1,822 Views)
Hi Gurdas,
here it is.
Mike
Message 625 of 1,444
(1,806 Views)
Could someone please help me convert the attached VIs to version 8.5?
Many thanks in advance
Message 626 of 1,444
(1,800 Views)
Hi helssoa,
it's already 8.5.
Edit: Is this your preparation for the CLD exam? 🙂
Mike
Message 627 of 1,444
(1,796 Views)
Would someone mind downconverting this VI from 8.6 to 8.5 then posting it here.
Thanks a lot!
Cory K
Message 628 of 1,444
(1,778 Views)
Could someone please convert this VI from 8.6 to 7 and post it here.
Thanks a lot!
Cory K
Message 629 of 1,444
(1,766 Views)
Can anybody help me down convert attached VI's to 7.1
Regards
Pete
Message 630 of 1,444
(1,737 Views)
