Downconvert VI Requests
Profravi,
I am getting a "Archive unknown or damaged" error from winrar.
Message 81 of 1,444
(4,437 Views)
Hi Profravi,
linking once is enough...
Well, the archive is ok when using WinZIP Smiley Wink But it requires installing "something" into a LV installation, so you have to be patient...
Message 82 of 1,444
(4,438 Views)
I downloaded the attached file for my power applications from NI. However these vi are not working in my Labview 7.1 ver.as these vi have been created in ver 8.6 0r above. Hence it is requested to please downconvert these vi from ver 8.6 to ver 7.1.
thanks & regards
ProfRavi
Message 83 of 1,444
(4,412 Views)
Hi everybody
I'currently working abroad and need the four VIs attached. Right now I have only access to LV 8.6.1. Could someone please downconvert these VIs from LV 9 to LV 8.6.1 for me?
Thanks a lot, Andre
Message 84 of 1,444
(4,391 Views)
Could you downconvert the two attached llbs from Labview 9 to 8.2?
Message 85 of 1,444
(4,379 Views)
Hi andreef,
someone else has converted those VIs from LV5 to LV2009 and now you need LV8.6 Smiley Wink
Before using them you should clean them up...
Message 86 of 1,444
(4,369 Views)
Hi roberto,
it's really not nice to attach LLBs with a lot of VIs, no Tree.vi, a lot of missing subVIs (lab2lowlevel.llb) and password-protection...
Due to the last point LV refuses to down-convert...
Message 87 of 1,444
(4,369 Views)
Thanks GerdW for your kind reply. I am attaching the full file which I downloaded from NI. Hope It may work. Alternatively I am also giving the link for downloading. As the file size is too large to attach.
 LabVIEW Code for Electrical Power Measurement (EPM) Resource Kit
 regards
 ProfRavi
Message 88 of 1,444
(4,339 Views)
Thanks muks for your efforts and reply. I am placing the link below from where it can be downloaded. As the file size is of more than 5.0 MB which is exceeding the limit of attachment here in this forum. Hope now now It can be downonverted from 8.6 to ver 7.1.
Download Link
Thanks & regards
Prof Ravi
Message 89 of 1,444
(4,296 Views)
Thanks GerdW for your reply. I have intalled the file but still it is not working as the vis in this application file have been creadted in ver 8.6 or above. so pls suggest what should i do ?
with best regards
Prof Ravi
Message 90 of 1,444
(4,295 Views)
