05-16-2011 03:17 PM
Working on it now....I'll edit this post once I'm finished doing the downconvert.
05-16-2011 08:01 PM
Thanks for your attention and awaiting the downconvert.
L
05-17-2011 02:16 PM
Sorry it's taking me so long to get back with this. I'm running into a lot of problems downconverting these VIs. It's possibly related to a file being missing. Many of these VIs are looking for the file "CCS_Series_Drv_32.dll." Do you have this file on hand?
05-17-2011 11:58 PM
Strange, since I do not get that error message. All I can think to do is upload an earlier version of the program which I hope will contain the relavent file.
Thanks for your efforts so far.
L
05-18-2011 05:31 PM
Can someone help me to convert these vi's from ver. 8.6 to ver 8.5? Apparently, they require IMAQ in order to convert them.
05-19-2011 09:25 AM
Regards,L
The DLL would not be contained inside of a LabVIEW library. If it's not in the director, then it's in your operating system's system folders. On Windows the DLL would most likely be in C:\Windows\system32.
Normally the DLL isn't required in order to do a downconvert. However, sometimes LabVIEW has a problem in down-converting VIs that use the CLFN (and also with some typedefs). I also tried to downconvert, and LabVIEW kept crashing.
05-19-2011 10:43 AM
Can someone please help me to down convert the VIs from Labview 2010 to Labview 2009....
Thanx.....
05-19-2011 01:57 PM - edited 05-19-2011 01:59 PM
Have the Design Pattern VIs been down-converted before? I was wondering if this could be down-converted to LV 7.1 (source is LV 10)
Thank you in advance!
05-19-2011 03:40 PM
Thanx.....
here ya go
05-19-2011 04:05 PM
Only one small example was previously done. Not sure if the attached will work for you. Since projects don't exist in LV 7.1 I had to create a VI and put all the VIs and controls on it in order to downconvert everything.
