Duty cycle measure
this is Antonio Guagnano, I'm working to a new project where I need to control heating system by means duty cycle measure. I attached an easy VI where I just check temperature.
Right now, I need to compare a fix duty cycle with calculated one as time heater on*100/ (time heater off+time heater on).
Can anyone help me?
Thanks in advance
AG
(2,513 Views)
Can anyone help me?
Thanks in advance
AG
(2,513 Views)
Accepted by topic author Antonio81
Hi AG,
no need to start two threads for the very same problem!
Your VI is a mess: don't (ab)use local variables!
Simplified:
check.png("T. Read" can be deleted when you make the digital display of "Temperature" visible…)
Where do you need to compare those "duty cycles"? There is nothing related in your VI…
(2,496 Views)
