Easy way to locate function used on Block Diagram by Name?
Is there an easy way to locate functions used on the Block Diagram by the Generic Function name?
I have user quite a few Display Message to User functions on my Block Diagram to help me debug a difficult sequence of events agross multiple VIs. Now that it is working, I would like to go back and disable most of those Display Messages. Most of them are tucked far inside quite a few layers of Structures and are not easy to find.
So is there an easy way to get a list of where these functions are used so that I can quickly go in and modify them?
(2,586 Views)
Accepted by dbaechtel
I located the Find function with the View Hierarchy that does just what I need.
THANKS.
(2,576 Views)
If you need to do this programatically, you can use the new Traverse for GObjects.vi in LabVIEW 2010.  I believe Darren released it in earlier versions, as well.  The code itself will work back to about LabVIEW 6i (it is scripting).
(2,543 Views)
