Editor >> Find and Replace text - can replacement string include a newline character?
This snippet will turn on codes display for all string controls in a VI.  It will try to cast everything into strings but I just clear the error and move on.
NOTE: I would not run this on your working copy unless you have a backup.  Just sayin'.....
aputman
Message 11 of 12
(587 Views)
If you are mucking with the display style, make sure to make the display style visible.  Many issues can be quickly figured out with that turned on.
Message 12 of 12
(565 Views)
