Elapsed timer to start stop the ouput with specified time and stop with while loop
I want to turn on the output for 10s and than off for 15s and run the cycle and want to stop the Vi as soon as i press while loop stop button.
please share the solution by showing block diagram.
Message 1 of 12
(1,796 Views)
There are millions of decent ways to do this...
None involve a global. 😉
You'll make a huge step if you learn about shift registers. And event structures.
Since you want to stop as soon as you press a button, an event structure makes a lot of sense:
Message 2 of 12
(1,777 Views)
Hi Holas,
Try the attached code below
Message 3 of 12
(1,749 Views)
Thank you,
but this Vi is of latest version V19.1 and my version is V15 , so not able to open .
any other way to open this , can you let me know .
Thnaks.
Message 4 of 12
(1,725 Views)
Thank you !!
Message 5 of 12
(1,715 Views)
Accepted by topic author Holas1505
Hi Hola,
Can you try again? Let us know if it works and if it does, do not forget to choose best answer.
Message 6 of 12
(1,703 Views)
Still not working, attached is snap for error details. thanks
Message 7 of 12
(1,678 Views)
Hi Holas,
Why do you even try to open a VI using AdobeAcrobat?
Why don't you use LabVIEW to open a VI?
Message 8 of 12
(1,667 Views)
Ohh really sorry, now it is working fine.
Thank you so much for your quick response, this realy help me well.
Message 9 of 12
(1,658 Views)
Does the code work as you were expecting? Let us know. If it works as expected, mark it as solution.
Message 10 of 12
(1,640 Views)
