Elapsed timer to start stop the ouput with specified time and stop with while loop
I want to turn on the output for 10s and than off for 15s and run the cycle and want to stop the Vi as soon as i press while loop stop button.
please share the solution by showing block diagram.
Message 1 of 12
(1,848 Views)
There are millions of decent ways to do this...
None involve a global. 😉
You'll make a huge step if you learn about shift registers. And event structures.
Since you want to stop as soon as you press a button, an event structure makes a lot of sense:
Message 2 of 12
(1,829 Views)
Hi Holas,
Try the attached code below
Message 3 of 12
(1,801 Views)
Thank you,
but this Vi is of latest version V19.1 and my version is V15 , so not able to open .
any other way to open this , can you let me know .
Thnaks.
Message 4 of 12
(1,777 Views)
Thank you !!
Message 5 of 12
(1,767 Views)
Accepted by Holas1505
Hi Hola,
Can you try again? Let us know if it works and if it does, do not forget to choose best answer.
Message 6 of 12
(1,755 Views)
Still not working, attached is snap for error details. thanks
Message 7 of 12
(1,730 Views)
Hi Holas,
Why do you even try to open a VI using AdobeAcrobat?
Why don't you use LabVIEW to open a VI?
Message 8 of 12
(1,719 Views)
Ohh really sorry, now it is working fine.
Thank you so much for your quick response, this realy help me well.
Message 9 of 12
(1,710 Views)
Does the code work as you were expecting? Let us know. If it works as expected, mark it as solution.
Message 10 of 12
(1,692 Views)
