Elegant modern UI way of displaying steps complete in a sequence
Hello everyone,
Is there a UI toolkit or a manual way to create a nice elegant modern UI way of displaying steps complete in a sequence? I've attached one example from the web.
I know the basic way in LabVIEW can be just a bunch of boolean indicators lined up and turned on one by one.
But I was looking for a nicer way of displaying, like the example I've attached... a node tree or node line where the completed steps all turn green up to the current step.
Thanks!
(2,525 Views)
Are you using NI TestStand?
It has LabVIEW GUI too.
George Zou
(2,523 Views)
Accepted by abvenk
Well, that's just a fancy Horizontal Progress Bar or Horizontal Graduated Bar
=== Engineer Ambiguously ===
(2,496 Views)
Ah of course!
I've used it a thousand times, but it didn't occur to me to overlap the progress bar with boolean indicators.
Thanks!
(2,478 Views)
@abvenk wrote:
Ah of course!
Thanks!
FYI, if you are referring to the picture, both pictures are of progress bars.  One is just a segmented progress bar.
Bill
CLD
(Mid-Level minion.)
(2,440 Views)
I like to use this.
(2,432 Views)
@billko wrote:
@abvenk wrote:
Ah of course!
Thanks!
I meant, I got my idea of how to implement the "node-segmented" progress bar that I had shared a picture of. If I overlapped round boolean indicators with a plain progress bar, I would achieve the "node-segmented" progress bar.
(2,348 Views)
