Embedding Windows media play in LabVIEW
I´ve tried to play AVIs (coded MPEG4) using ActiveX Plug-in of Windows Media Player.
The problem appears when I change the window appearance property.
If the property "window has title bar" is unchecked, the video will not be shown, but the sound track (formated MP3) is still loaded.
So how can I play the video without title bar?
BR,
Wilbur
Message 1 of 10
(6,167 Views)
In some project I have used the Quick Time player ActiveX component. It is better than the Windows Mediaplayer. Quick Time is free to download.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 2 of 10
(6,153 Views)
I´ve tried QuickTime but it doesn´t recognize the AVI because of the MPEG4 code.
However, it doesn´t appear in Windows Media Player.
Message 3 of 10
(6,148 Views)
Also the VLC player do have an ActiveX component. Try a search in this forum.
Message 4 of 10
(6,137 Views)
Message 5 of 10
(6,134 Views)
Hi there,
I´m using the VLC, but during playing the VLC cannot return the time information. If the time or position is asked, there will be an error!
PS: There´s also an IO error for uploading picture in the forum!
Message 6 of 10
(6,115 Views)
Can you give the details?
Message 7 of 10
(6,084 Views)
the error disappears, it might come with a temp network problem.
I´ve got another question with the VLC ActiveX. How can I hide the file name at the begin of the playback?
Message 8 of 10
(6,050 Views)
I don't know if this will help but....
I have attached an example using Windows Media Player to play MP3's I found here years ago.
=== Engineer Ambiguously ===
Message 9 of 10
(6,033 Views)
Accepted by wilburwu
Solution found
VLC ActiveX provides the option, in which the user may config the player. Using "no-video-title-show" or "no-osd" may disable the title at the start of the playback or the subtitle during playback.
Message 10 of 10
(5,976 Views)
