Encrypte file
I want to encrypte my .TDMS file and the file couldn't open anywhere other than software. Is there any way to encrypte the TDMS file?
Yasemin Barutçu
Electrical And Electronics Engineer
Message 1 of 11
(6,876 Views)
Message 2 of 11
(6,871 Views)
I didn't understand it very good but I guess its not working for me.
programmatically encode the TDMS file so noone could open it using excel or Diadem I meant.
Yasemin Barutçu
Message 3 of 11
(6,847 Views)
No_RegreTs,
Could you describe your "tdms file encryption" requirement in detail? e.g., who (which tool) encrypt tdms file? who (which tool) decrypt the encrypted tdms file?
Message 4 of 11
(6,844 Views)
Could Blowfish (http://zone.ni.com/devzone/cda/epd/p/id/3473) help you achieve your purpose?
Message 5 of 11
(6,843 Views)
I studied this algorithm but I couldn't understand how to encode my file. Its data  Encryption but I want file  Encryption. Or I understood all of these algorithms wrong.
Yasemin Barutçu
Message 6 of 11
(6,838 Views)
Accepted by No_RegreTs
OpenG has a Zip utility (http://wiki.openg.org/Oglib_lvzip) with password support. Does it satisfy your requirement?
Attached is a sample VI to Zip and UnZip a file with password.
Message 7 of 11
(6,826 Views)
Do I have to buy license for that ? To use this vi's and make them executable?
Yasemin Barutçu
Message 8 of 11
(6,813 Views)
Are you trying to encrypt it as the data's being generated (difficult without native support), or is it acceptable to encrypt the data after the TDMS file's been closed?
On Linux/Unix boxes, "openssl" via commandline is a quick/free way to encrypt/decrypt files.  Pass in input file, output file, a few parameters for encryption, a password, and let it go.  Could take a while on bigger files.
Message 9 of 11
(6,808 Views)
No_RegreTs,
OpenG Oglib lvzip is open source. According to http://wiki.openg.org/Oglib_lvzip-2.5, it is BSD license. Generally BSD is a commercial friend open source license.
(if it satisfies your tech requirement) You might ask your lawyer to evaluate whether your product could use it or not, from license point of view.
Message 10 of 11
(6,786 Views)
