End user selecting com ports
I am new to using visa serial.
I have some code that on my dev-station the front pannel drop down box gives you selections like Com1 Com2.
When I compile and build this the end user sees ASRL-1::INSTR and ASRL-2::INSTR.
End users find this very confusing.
Also what is the best way to have an end user select a com port and  make sure it is a valid selection without causing errors that abort the program?
=== Engineer Ambiguously ===
(2,737 Views)
Using the visa resource control with filtering (filter com ports) allows the user to select only valid ports.  I like to capture value change events and probe the device (a query command) to validate the device is connected and working.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,733 Views)
