Enqueue element only if it is an updated value
Thanks, guys, for setting me straight...I thought that the wires were made of pasta!
Which, come to think of it, is still a consumable.
Message 11 of 19
(1,374 Views)
DianeS,
See the spaghetti code thread in the Breakpoint forum for details on pasta wiring.
Lynn
Message 12 of 19
(1,369 Views)
Mine are 100% fiber optic. 😉 The color is determined by the wavelength of the signal.
Message 13 of 19
(1,367 Views)
Lynn, that was the thread (spaghetti noodle?) that I had in mind when I posted.  Smiley Very Happy
Altenbach, what happens to the wire color when your wavelength is greater than ~780nm?
Message 14 of 19
(1,363 Views)
I'm thinking the block diagram becomes unreadable?
Message 15 of 19
(1,357 Views)
You just need to move your head fast enough to get a doppler shift.
Message 16 of 19
(1,354 Views)
That would get awfully confusing (as well as requiring a LOT of coffee, not to mention experimentation, to calibrate the necessary head jitter), since Boolean wires would start to look a lot like integer wires.
And variant wires would become invisible.
Hmm.
Message 17 of 19
(1,348 Views)
Haven't you felt the heat radiating from the screen due to infrared wires?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 18 of 19
(1,339 Views)
Hmm.
I think you get an "Insane Object" warning <between monitor and chair>.  <Dwarn: UserSane> LabVIEW must close.  Please contact National Instruments psychopharmacy assistance.
Message 19 of 19
(1,323 Views)
