Error 1 occurred at You did not specify any startup VIs. Select a startup VI before building the application.
Hi  All,
I am new to labVIEW, i am trying to build an application Freqresponse.exe from the NI example Frequencyresponse.vi
wheni press build button on buildspecifications error pop's up and saying you have to select a startup VI before building
I am using Evaluation version of 8.5
Pradeep Appala
(4,505 Views)
Well, did you specify a startup VI? In the build properties, there is a category called Source Files. In the center of this window, is a list of the project files. Select the top level VI and click the arrow to add it to the list of Startup VIs. If you open the on-line help, search for 'stand-alone applications' and open the 'building (how-to)' topic for a step-by step description.
(4,503 Views)
Thanks Dennis,
Now i was able to generate stand-alone application
If u don't mind can u tell me how can i go to online help do you mean by Ctrl+?
Pradeep Appala
(4,497 Views)
