Error 1003 .... Append Numeric Table to Report.vi VI is not executable
My application is fully functional in the developement mode. When trying to build Application I get the above error message! I have used this vi in previous versions of my application and the build was functional.
(2,919 Views)
Try reinstalling the LabVIEW runtime engine. You can donwload your version of the runtime engine here:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C0CFF?opendocument&node=132070_US
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,919 Views)
I have tried reinstalling the runtime engine, however this error occurs when I am trying to build my application.
(2,919 Views)
Wed,
When you go into that VI, what is broken? Probably nothing. Try mass compiling the VI and see if that helps.
We have seen this problem before when one has installed an older version of NI Reports over a newer version. To fix this, run regedit from Start»Run and go to HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\NI-Reports and delete it. Next, delete \shared\NI-Reports folder. Then re-install the Run-time Engine.
Randy Hoskin
http://www.ni.com/ask
(2,918 Views)
